Although the LP print service is designed to be flexible enough to handle most printers and printing needs, it does not handle every possible situation. You might have a print request that is not accommodated by the standard features of the LP print service. Or you can have a printer that does not quite fit into the way the LP print service handles printers.
You can customize the LP print service in the following ways:
Adjust the printer port characteristics
Adjust the terminfo database
Customize the printer interface program
Create a print filter
Define a form
For detailed descriptions and step-by-step instructions to customize the LP print service, see Chapter 7, Customizing the LP Print Service (Tasks).
