System Administration Guide: Advanced Administration
Syntax of crontab File Entries
A crontab file consists of commands, one per line, that execute automatically at the time specified by the first five fields at the beginning of each command line. These first five fields, described in the following table, are separated by spaces.
Table 18–3 Acceptable Values for crontab Time Fields
Time Field
Values
Minute
0-59
Hour
0-23
Day of month
1-31
Month
1-12
Day of week
0-6 (0 = Sunday)
Follow these guidelines for using special characters in crontab time fields:
For example, the following crontab command entry displays a reminder in the user's console window at 4 p.m. on the first and fifteenth of every month.
0 16 1,15 * * echo Timesheets Due > /dev/console
Each command within a crontab file must consist of one line, even if that line is very long, because crontab does not recognize extra carriage returns. For more detailed information about crontab entries and command options, refer to crontab(1).
