The following /etc/vfstab example shows that the /export/home directory from the system pluto is mounted as an NFS file system on the local system. You can tell quotas are enabled by the rq entry under the mount options column.
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # pluto:/export/home - /export/home nfs - yes rq |
The following example line from /etc/vfstab shows that the local /work directory is mounted with quotas enabled, signified by the rq entry under the mount options column.
#device device mount FS fsck mount mount #to mount to fsck point type pass at boot options # /dev/dsk/c0t4d0s0 /dev/rdsk/c0t4d0s0 /work ufs 3 yes rq |
