The following example shows the contents of the temporary file opened by the edquota command on a system where /files is the only mounted file system that contains a quotas file in the file system's root directory.
fs /files blocks (soft = 50, hard = 60) inodes (soft = 90, hard = 100) |
The following example shows the same temporary file after quotas have been disabled.
fs /files blocks (soft = 0, hard = 0) inodes (soft = 0, hard = 0) |
