When you use the interactive command, a ufsrestore> prompt is displayed, as shown in this example:
# ufsrestore ivf /dev/rmt/0 Verify volume and initialize maps Media block size is 126 Dump date: Thu Aug 30 10:13:46 2001 Dumped from: the epoch Level 0 dump of /export/home on starbug:/dev/dsk/c0t0d0s7 Label: none Extract directories from tape Initialize symbol table. ufsrestore > |
At the ufsrestore> prompt, you can use the commands listed on “UFS Backup and Restore Commands (Reference)” in System Administration Guide: Basic Administration to find files, create a list of files to be restored, and restore them.
