This chapter provides procedures for creating and working with an interface group, configuring test addresses, configuring the hostname file, and configuring the multipathing configuration file.
This chapter contains the following information:
Replacing a Physical Interface That Has Failed or DR-detaching/DR-attaching a Physical Interface
Recovering a Physical Interface That Was Not Present at System Boot
This section provides procedures for configuring multipathing interface groups. It also describes how to make an interface a hot standby interface.
Grouping Physical Interfaces provides additional information.
Task |
Description |
For Instructions, Go to .. |
Configuring a multipathing interface group with two interfaces |
Use the ifconfig command, the group parameter, -failover option, the deprecated option, and the /etc/hostname.interface file |
How to Configure a Multipathing Interface Group With Two Interfaces |
Configuring a multipathing group where one of the interfaces is a standby interface |
Use the ifconfig command, the group parameter, standby parameter, -failover option, and the /etc/hostname.interface file |
How to Configure a Multipathing Group With One of the Interfaces a Standby Interface |
Displaying the group to which a physical interface belongs |
Use the ifconfig command and the interface name |
How to Display the Group to Which a Physical Interface Belongs |
Adding an interface to a group |
Use the ifconfig command and the interface name | |
Removing an interface from a group |
Use the ifconfig command and a null string to disable IP network multipathing | |
Moving an interface from an existing group to a different group |
Use the ifconfig command and the group parameter |
How to Move an Interface From an Existing Group to a Different Group |
Become superuser.
Place each physical interface into a multipathing group by typing the following command.
# ifconfig interface-name group group-name |
For example, to place hme0 and hme1 under group test, you type the following commands:
# ifconfig hme0 group test # ifconfig hme1 group test |
Configure a test address for all the physical interfaces.
For an IPv4 test address, type the following command.
This step assumes that you have already configured your physical interfaces' addresses.
# ifconfig interface-name addif ip-address <parameters> -failover deprecated up |
For example, to configure a test address on hme0 with the following configuration:
Address set to 19.16.85.21
Netmask and broadcast address set to the default value
-failover and deprecated options set
You type the following command:
# ifconfig hme0 addif 19.16.85.21 netmask + broadcast + -failover deprecated up |
You can check the configuration by typing the following:
# ifconfig hme0:1
hme0:1: flags=9000843<UP,BROADCAST,RUNNING,MULTICAST,DEPRECATED,IPv4,NOFAILOVER>
mtu 1500 index 2 inet 19.16.85.21 netmask ffffff00 broadcast 19.16.85.255
You must mark an IPv4 test address as deprecated to prevent applications from using the test address.
To configure a test address on hme1 with the following configuration:
Address set to 19.16.85.22
Type the following command:
# ifconfig hme1 addif 19.16.85.22 netmask + broadcast + -failover deprecated up |
For an IPv6 test address, type the following command.
# ifconfig interface-name inet6 -failover |
Because you have already placed the physical interfaces with IPv4 addresses into a multipathing group, physical interfaces with IPv6 addresses are also implicitly placed in the same multipathing group. You might have placed physical interfaces with IPv6 addresses into a multipathing group first. Then physical interfaces with IPv4 addresses would have been also implicitly placed in the same multipathing group.
For example, to configure hme0 with an IPv6 test address, you type the following command:
# ifconfig hme0 inet6 -failover |
hme0: flags=a000841<UP,RUNNING,MULTICAST,IPv6,NOFAILOVER> mtu 1500
index 2 inet6 fe80::a00:20ff:feb9:17fa/10
groupname test
You do not need to mark an IPv6 test address as deprecated to prevent applications from using the test address.
For the second interface, hme1, type the following command:
# ifconfig hme1 inet6 -failover |
(Do this step only if you want to preserve the configuration across reboots.) To preserve the configuration across reboots, do the following substeps.
For IPv4, edit the /etc/hostname.interface file and add the following line.
interface-address <parameters> group group-name up \ addif logical-interface -failover deprecated <parameters> up |
This test IP address is configured only on the next reboot. If you want the configuration to be invoked in the current session, do steps 1, 2, and 3.
For example, to create a group test with the following configuration for hme0:
Physical interface hme0 with address 19.16.85.19
A logical interface address of 19.16.85.21
With deprecated and -failover set
Sets the netmask and broadcast address to the default value
You add the following line to the /etc/hostname.hme0 file:
19.16.85.19 netmask + broadcast + group test up \ addif 19.16.85.21 deprecated -failover netmask + broadcast + up |
Similarly, to place hme1 under the same group test and configure a test address, type the following command:
19.16.85.20 netmask + broadcast + group test up \ addif 19.16.85.22 deprecated -failover netmask + broadcast + up |
For IPv6, edit the /etc/hostname6.interface file and add the following line.
-failover group group-name up |
For example, to create a test group for hme0 with an IPv6 address, add the following line to the /etc/hostname6.hme0 file:
-failover group test up |
Similarly, to place hme1 under the same group test and configure a test address, add the following line to the /etc/hostname6.hme1 file:
To add more interfaces to the multipathing group, repeat steps 1 through 3. New interfaces can be added to an existing group on a live system. However, changes are lost across reboots.
The examples that are used in this procedure assume that hme1 will be configured as the standby interface.
A standby interface has only a test address.
Do steps 1 and 2 in How to Configure a Multipathing Interface Group With Two Interfaces.
Configure the test address on all physical interfaces by using the following substeps.
For the non-standby interface, such as hme0, do step 3 in How to Configure a Multipathing Interface Group With Two Interfaces.
For a standby interface, configure a test address by typing the following command.
A standby interface can have only a test address. A standby interface cannot have any other IP address.
# ifconfig interface-name plumb ip-address <other-parameters> deprecated -failover standby up |
You must set the -failover option before the standby option and the standby option before up.
For <other-parameters>, use the parameters that are required by your configuration. See the ifconfig(1M) man page for descriptions.
For example, to create a test address with the following configuration:
Physical interface hme1 as a standby interface
Address of 19.16.85.22
# ifconfig hme1 plumb 19.16.85.22 netmask + broadcast + deprecated -failover standby up |
You can check the results by typing the following:
# ifconfig hme1
flags=69040843<UP,BROADCAST,RUNNING,MULTICAST,DEPRECATED,IPv4,NOFAILOVER,STANDBY,INACTIVE>
mtu 1500 index 4 inet 19.16.85.22 netmask ffffff00 broadcast 19.16.85.255
groupname test
For IPv6, to create a test address, type the following command:
ifconfig hme1 plumb -failover standby up |
The INACTIVE flag indicates that this interface is not used for any outbound packets. When a failover occurs on this standby interface, the INACTIVE flag is cleared.
interface-address <parameters> group group-name up \ addif logical-interface-failover deprecated <parameters> up |
This test IP address is configured only on the next reboot. If you want the configuration to be invoked in the current session, do steps 1 and 2.
Similarly, to place the standby interface hme1 under the same group test and configure a test address, type the following command:
19.16.85.22 netmask + broadcast + deprecated group test -failover standby up |
Similarly, to place the standby interface hme1 under the same group test and configure a test address, add the following line to the /etc/hostname6.hme1 file:
-failover group test standby up |
For example, to display the group name for hme0, you type the following command:
# ifconfig hme0
hme0: flags=9000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4> mtu 1500
index 2 inet 19.16.85.19 netmask ffffff00 broadcast 19.16.85.255
groupname test
To display the group name for only the IPv6 instance, you type the following command:
hme0: flags=a000841<UP,RUNNING,MULTICAST,IPv6> mtu 1500 index 2
inet6 fe80::a00:20ff:feb9:19fa/10
groupname test
Become superuser.
On a command line, type the following command.
For example, to add hme0 to the group test, you type the following command:
# ifconfig hme0 group test |
Become superuser.
# ifconfig interface-name group "" |
The quotation marks indicate a null string.
For example, to remove hme0 from the group test, you type the following command:
# ifconfig hme0 group ""
# ifconfig hme0
Removing Network Adapters From Multipathing Groups provides additional information.
Become superuser.
Placing the interface in a new group automatically removes it from any existing group.
For example, to remove hme0 from group test and place it in group cs-link, you type the following:
# ifconfig hme0 group cs-link |
This command removes the interface from any existing group and then puts the interface in the group cs-link.
The steps in this section pertain to only IP layers that are configured by using ifconfig(1M). Layers above or below the IP layer, such as ATM or other services, require specific manual steps if the layers are not automated. The specific steps are used to unconfigure during pre-detach and configure after post-attach. See the layers and applications documentation for instructions on how to handle the failure and DR scenarios.
You must do the following manual steps before replacing a physical interface that has failed. The following procedures use physical interfaces hme0 and hme1 as example interfaces. The procedures assume that both interfaces are in a multipathing group and that hme0 has failed. The procedures also assume that the logical interface hme0:1 has the test address.
These procedures assume that you are replacing the failed interface with the same physical interface name (for example, hme0 with hme0).
You can skip step 1 if the test address is plumbed by using the /etc/hostname.hme0 file.
Retrieve the test address configuration by typing the following command.
# ifconfig hme0:1 hme0:1: flags=9040842<BROADCAST,RUNNING,MULTICAST,DEPRECATED,IPv4,NOFAILOVER> mtu 1500 index 3 inet 129.146.233.250 netmask ffffff00 broadcast 129.146.233.255 |
You need this information to replumb the test address when replacing the physical interface.
See Using the hostname File to Configure Groups and Test Addresses for details on how to configure test addresses by using the hostname file.
Refer to the cfgadm(1M) man page, Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide, or Sun Enterprise 10000 DR Configuration Guide for a description of how to remove the physical interface.
Refer to the cfgadm(1M) man page, Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide, or Sun Enterprise 10000 DR Configuration Guide, or Sun Fire 880 Dynamic Reconfiguration User's Guide for a description of how to replace the physical interface.
Plumb in and bring up the test address by typing the following command.
# ifconfig hme0 <test address configuration> |
The test address configuration is the same test address that was configured in the /etc/hostname.hme0 file. Using the previous procedure, the test configuration is the same configuration that is displayed in step 1.
This configuration triggers the in.mpathd daemon to resume probing. As a result of this probing, in.mpathd detects the repair. Consequently, in.mpathd causes the original IP address to fail back from hme1.
See Configuring Test Addresses for more details about how to configure test addresses.
The failback of IP addresses during the recovery of a failed physical interface requires as much as three minutes. This time might vary. The time depends on network traffic. The time also depends on the determination of the stability of the incoming interface to failback failed over interfaces by the in.mpathd daemon.
Recovery after a DR operation for a NIC that is part of the IO board on a Sun Fire platform or if the NIC is a cPCI device is automatic. Consequently, the following steps are not required for a NIC that is coming back as part of a DR operation. For more information on the Sun Fire x800 and Sun Fire 15000, see the cfgadm_sbd(1M) man page. The physical interface is recovered to the configuration that is specified in the /etc/hostname.interface file. See Configuring Multipathing Interface Groups for details on how to configure interfaces to preserve the configuration across reboots.
On Sun Fire legacy (Exx00) systems, DR detaches are still subject to manual procedures. However, DR attaches are automated.
You must do the following manual steps before recovering a physical interface that was not present at system boot. The following procedure uses physical interfaces hme0 and hme1 as example interfaces. The procedure assumes that both interfaces are in a multipathing group and that hme0 was not present at system boot.
The failback of IP addresses during the recovery of a failed physical interface last three minutes. This time might vary. The time depends on network traffic. The time also depends on the determination of the stability of the incoming interface to fail back failed-over interfaces by the in.mpathd daemon.
Retrieve the failed network information from the console log failure error message.
See the syslog(3C)man page. The error message might be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (moved to hme0) |
The error message might also be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (couldn't move, no alternative interface) |
Attach the physical interface to the system.
Refer to the cfgadm(1M) man page, Sun Enterprise 10000 DR Configuration Guide, or Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide for a description of how to replace the physical interface.
Refer to the message content from step 1. If the addresses could not be moved, go to step 5. If the addresses were moved, do step 4.
Unplumb the logical interfaces that are configured as part of the failover process by doing the following substeps.
Look at the contents of the file /etc/hostname.<moved_from_interface> to see what logical interfaces were configured as part of the failover process.
Unplumb each failover IP address by typing the following command:
# ifconfig moved_to_interface removeif moved_ip_address |
Failover addresses are those addresses that are marked with the failover parameter, or those addresses that are not marked with the -failover parameter. You do not need to unplumb IP addresses that are marked -failover.
For example, assume that the contents of the /etc/hostname.hme0 file contained the following lines:
inet 1.2.3.4 -failover up group one addif 1.2.3.5 failover up addif 1.2.3.6 failover up |
Then, to unplumb each failover IP address, you would type the following commands:
# ifconfig hme0 removeif 1.2.3.5 # ifconfig hme0 removeif 1.2.3.6 |
Reconfigure the IPv4 information for the replaced physical interface by typing the following command for each interface that was removed.
# ifconfig removed_from_NIC <parameters> |
By using the example in step 4, you would type the following commands:
# ifconfig hme1 inet plumb # ifconfig hme1 inet 1.2.3.4 -failover up group one # ifconfig hme1 addif 1.2.3.5 failover up # ifconfig hme1 addif 1.2.3.6 failover up |
The multipathing /etc/default/mpathd configuration file contains three parameters that you can adjust for your configuration requirements:
FAILURE_DETECTION_TIME
FAILBACK
TRACK_INTERFACES_ONLY_WITH_GROUPS
See Multipathing Configuration File for a description of these parameters.
