System Administration Guide: IP Services
How to Capture snoop Results to a File
  1. Become superuser.
  2. On the command line, type the following command.
    # snoop -o filename
    For example:
    # snoop -o /tmp/cap
    Using device /dev/le (promiscuous mode)
    30 snoop: 30 packets captured
    By using this command, you have captured 30 packets in a file /tmp/cap. The file can be anywhere with enough disk space. The number of packets that are captured is displayed on the command line, enabling you to press Control-C to abort at any time.
    snoop creates a noticeable networking load on the host machine, which can distort the results. To see the actual results, run snoop from a third system (see the next section).
  3. On the command line, type the following command to inspect the file.
    # snoop -i filename
    For example:
    # snoop -i /tmp/cap
    1  0.00000 frmpk17b-082 -> 224.0.0.2    IP  D=224.0.0.2 S=129.146.82.1 LEN=32, ID=0
    2  0.56104        scout -> (broadcast)  ARP C Who is 129.146.82.63, grail ?
    3  0.16742  atlantic-82 -> (broadcast)  ARP C Who is 129.146.82.76, honeybea ?
    4  0.77247        scout -> (broadcast)  ARP C Who is 129.146.82.63, grail ?
    5  0.80532 frmpk17b-082 -> (broadcast)  ARP C Who is 129.146.82.92, holmes ?
    6  0.13462        scout -> (broadcast)  ARP C Who is 129.146.82.63, grail ?
    7  0.94003        scout -> (broadcast)  ARP C Who is 129.146.82.63, grail ?
    8  0.93992        scout -> (broadcast)  ARP C Who is 129.146.82.63, grail ?
    9  0.60887        towel -> (broadcast)  ARP C Who is 129.146.82.35, udmpk17b-82 ?
    10 0.86691  nimpk17a-82 -> 129.146.82.255 RIP R (1 destinations)
    Refer to specific protocol documentation for detailed analysis and recommended parameters for ARP, IP, RIP and so forth. The Web contains a number of requests for comments.
