Task |
Description |
For Instructions, Go To ... |
Configure a machine as a router |
Involves creating hostname and hosts file and adding addresses | |
Select static routing on a host that is a network client |
Involves adding an entry into the defaultrouter file |
How to Select Static Routing on a Host That Is a Network Client |
Select dynamic routing on a host that is a network client |
Involves editing entries in the defaultrouter file |
How to Select Dynamic Routing on a Host That Is a Network Client |
Force a machine to be a router |
Involves creating a gateways file |
