System Administration Guide: IP Services
Network Classes
The first step in planning for IPv4 addressing on your network is to determine which network class is appropriate for your network. After you have completed this step, you can move to the crucial second step: obtain the network number from the InterNIC addressing authority.
Currently there are three classes of TCP/IP networks. Each class uses the 32-bit IPv4 address space differently, providing more or fewer bits for the network part of the address. These classes are class A, class B, and class C.
Class A Network Numbers
A class A network number uses the first 8 bits of the IPv4 address as its “network part.” The remaining 24 bits compose the host part of the IPv4 address, as the following figure illustrates.
Figure 5–4 Byte Assignment in a Class A Address
Diagram shows bits 0-7 is network part and remaining 24 bits are host part of a 32 bit IPv4 Class A address.
The values that are assigned to the first byte of class A network numbers fall within the range 0–127. Consider the IPv4 address 75.4.10.4. The value 75 in the first byte indicates that the host is on a class A network. The remaining bytes, 4.10.4, establish the host address. The InterNIC assigns only the first byte of a class A number. Use of the remaining three bytes is left to the discretion of the owner of the network number. Only 127 class A networks can exist. Each one of these numbers can accommodate a maximum of 16,777,214 hosts.
Class B Network Numbers
A class B network number uses 16 bits for the network number and 16 bits for host numbers. The first byte of a class B network number is in the range 128–191. In the number 129.144.50.56, the first two bytes, 129.144, are assigned by the InterNIC, and compose the network address. The last two bytes, 50.56, compose the host address, and are assigned at the discretion of the owner of the network number. The following figure graphically illustrates a class B address.
Figure 5–5 Byte Assignment in a Class B Address
Diagram shows bits 0-15 is network part and remaining 16 bits are host part of a 32 bit IPv4 Class B address.
Class B is typically assigned to organizations with many hosts on their networks.
Class C Network Numbers
Class C network numbers use 24 bits for the network number and 8 bits for host numbers. Class C network numbers are appropriate for networks with few hosts—the maximum being 254. A class C network number occupies the first three bytes of an IPv4 address. Only the fourth byte is assigned at the discretion of the network owners. The following figure graphically represents the bytes in a class C address.
Figure 5–6 Byte Assignment in a Class C Address
Diagram shows bits 0-23 is network part and remaining 8 bits are host part of a 32 bit IPv4 Class C address.
The first byte of a class C network number covers the range 192–223. The second and third bytes each cover the range 1– 255. A typical class C address might be 192.5.2.5. The first three bytes, 192.5.2, form the network number. The final byte in this example, 5, is the host number.
