Become superuser on the system where you are enabling Mobile IP.
On a command line, type the following command.
# mipagentstat <option> |
You can use the following options:
-f |
Shows the list of active mobile nodes in the foreign agent's visitor list |
-h |
Shows the list of active mobile nodes in the home agent's binding table |
-p |
Shows the list of security associations with an agent's mobility agent peers |
For example, to show the visitor list for all mobile nodes that are registered with the foreign agent, use the following command.
# mipagentstat -f |
This command causes the following results to be displayed (for example).
Mobile Node Home Agent Time (s) Time (s) Flags
Granted Remaining
foobar.xyz.com ha1.xyz.com 600 125 .....T.
10.1.5.23 10.1.5.1 1000 10 .....T.
To show the foreign agent security associations, use the following command.
# mipagentstat -p |
Foreign ..... Security Association(s)..... Agent Requests Replies FTunnel RTunnel ---------------------- -------- -------- -------- -------- forn-agent.eng.sun.com AH AH ESP ESP |
To show the home agent security associations, use the following command.
# mipagentstat -fp |
Home ..... Security Association(s) ..... Agent Requests Replies FTunnel RTunnel ---------------------- -------- -------- -------- -------- home-agent.eng.sun.com AH AH ESP ESP ha1.xyz.com AH,ESP AH AH,ESP AH,ESP |
