Become superuser on the system where you want to enable Mobile IP.
On a command line, type the following command for each label that you want to modify in the Address section.
# mipagentconfig change addr [NAI | IPaddr | node-default] <label> <value> |
See Address Section for a description of the three configuration methods (NAI, IP address, and node-default).
For example, if you are changing the SPI of IP address 10.1.1.1 to 258, use the following command.
# mipagentconfig change addr 10.1.1.1 SPI 258 |
The following example shows how you can change other parameters that provided in the sample configuration file's Address section.
# mipagentconfig change addr 10.1.1.1 Type agent # mipagentconfig change addr 10.1.1.1 SPI 259 # mipagentconfig change addr mobilenode@abc.com Type node # mipagentconfig change addr mobilenode@abc.com SPI 258 # mipagentconfig change addr mobilenode@abc.com Pool 2 # mipagentconfig change addr node-default SPI 259 # mipagentconfig change addr node-default Pool 3 # mipagentconfig change addr 10.68.30.36 Type agent # mipagentconfig change addr 10.68.30.36 SPI 260 # mipagentconfig change IPsecRequest apply {auth_algs md5 sa shared} |
