System Administration Guide: IP Services
How to Modify the Advertisements Section
  1. Become superuser on the system where you want to enable Mobile IP.
  2. On a command line, type the following command for each label that you want to modify in the Advertisements section.
    # mipagentconfig change adv device-name <label> <value>
For example, if you are changing the agent's advertised lifetime to 300 seconds for device le0, use the following command.
# mipagentconfig change adv le0 AdvLifetime 300
The following example shows how you might change other parameters in the configuration file's Advertisements section.
Example 24–2 Changing Parameters in the Advertisements Section
# mipagentconfig change adv le0 HomeAgent yes
# mipagentconfig change adv le0 ForeignAgent no
# mipagentconfig change adv le0 PrefixFlags no
# mipagentconfig change adv le0 RegLifetime 300
# mipagentconfig change adv le0 AdvFrequency 4
# mipagentconfig change adv le0 ReverseTunnel yes
