You can use the mipagentconfig get command to display current settings that are associated with parameter destinations.
Become superuser on the system where you are enabling Mobile IP.
On a command line, type the following command for each parameter for which you want to display settings.
# mipagentconfig get [<parameter> | <label>] |
For example, if you are displaying the advertisement settings for the le0 device, use the following command.
# mipagentconfig get adv le0 |
This command causes the following results to be displayed (for example).
[Advertisements le0] HomeAgent = yes ForeignAgent = yes |
The following example shows the results of using the mipagentconfig get command with other parameter destinations.
# mipagentconfig get MaxClockSkew [GlobalSecurityParameters] MaxClockSkew=300 # mipagentconfig get HA-FAauth [GlobalSecurityParameters] HA-FAauth=no # mipagentconfig get MN-FAauth [GlobalSecurityParameters] MN-FAauth=no # mipagentconfig get Challenge [GlobalSecurityParameters] Challenge=no # mipagentconfig get Pool 10 [Pool 10] BaseAddress=192.168.1.1 Size=100 # mipagentconfig get SPI 257 [SPI 257] Key=11111111111111111111111111111111 ReplayMethod=none # mipagentconfig get SPI 258 [SPI 258] Key=15111111111111111111111111111111 ReplayMethod=none # mipagentconfig get addr 10.1.1.1 [Address 10.1.1.1] SPI=258 Type=agent # mipagentconfig get addr 192.168.1.200 [Address 192.168.1.200] SPI=257 Type=node # mipagentconfig get addr 10.1.1.1 [Address 10.1.1.1] Type=agent SPI=258 IPsecRequest = apply {auth_algs md5 sa shared} IPsecReply = permit {auth_algs md5} IPsecTunnel = apply {encr_algs 3des sa shared} |
