The default Solaris installation provides the following sample configuration files in the /etc/inet directory:
mipagent.conf-sample – Contains a sample configuration for a Mobile IP agent that provides both foreign and home agent functionality.
mipagent.conf.fa-sample – Contains a sample configuration for a Mobile IP agent that provides only foreign agent functionality.
mipagent.conf.ha-sample – Contains a sample configuration for a Mobile IP agent that provides only home agent functionality.
These sample configuration files contain mobile node address and security settings. Before you can implement Mobile IP, you must create a configuration file with the name mipagent.conf and place it in the /etc/inet directory. This file contains the configuration settings that satisfy your Mobile IP implementation requirements. You can also choose one of the sample configuration files, modify it with your addresses and security settings, and copy it to /etc/inet/mipagent.conf.
How to Create the Mobile IP Configuration File shows the procedures to perform.
The following listing shows the sections, labels, and values that are contained in the mipagent.conf-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values.
[General]
Version = 1.0 # version number for the configuration file. (required)
[Advertisements hme0]
HomeAgent = yes
ForeignAgent = yes
PrefixFlags = yes
AdvertiseOnBcast = yes
RegLifetime = 200
AdvLifetime = 200
AdvFrequency = 5
ReverseTunnel = no
ReverseTunnelRequired = no
[GlobalSecurityParameters]
MaxClockSkew = 300
HA-FAauth = yes
MN-FAauth = yes
Challenge = no
KeyDistribution = files
[Pool 1]
BaseAddress = 10.68.30.7
Size = 4
[SPI 257]
ReplayMethod = none
Key = 11111111111111111111111111111111
[SPI 258]
ReplayMethod = none
Key = 15111111111111111111111111111111
[Address 10.1.1.1]
Type = node
SPI = 258
[Address mobilenode@sun.com]
Type = node
SPI = 257
Pool = 1
[Address Node-Default]
Type = node
SPI = 258
Pool = 1
[Address 10.68.30.36]
Type = agent
SPI = 257
Type = agent
SPI = 257
IPsecRequest = apply {auth_algs md5 sa shared}
IPsecReply = permit {auth_algs md5}
IPsecTunnel = apply {encr_algs 3des sa shared}
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.fa-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values. The mipagent.conf.fa-sample file shows a configuration that provides only foreign agent functionality. This sample file does not contain a Pool section, because pools are used only by a home agent. Otherwise, this file is the same as the mipagent.conf-sample file.
[General]
HomeAgent = no
ForeignAgent = yes
PrefixFlags = yes
RegLifetime = 200
AdvLifetime = 200
AdvFrequency = 5
ReverseTunnel = yes
MaxClockSkew = 300
HA-FAauth = yes
MN-FAauth = yes
Challenge = no
[SPI 257]
ReplayMethod = none
[SPI 258]
ReplayMethod = none
[Address 10.1.1.1]
Type = node
SPI = 258
Type = agent
SPI = 257
Type = agent
SPI = 257
The following listing shows the sections, labels, and values that are contained in the mipagent.conf.ha-sample file. Configuration File Sections and Labels describes the syntax, sections, labels, and values. The mipagent.conf.ha-sample file shows a configuration that provides only home agent functionality. Otherwise, this file is the same as the mipagent.conf-sample file.
[General]
HomeAgent = yes
ForeignAgent = no
PrefixFlags = yes
RegLifetime = 200
AdvLifetime = 200
AdvFrequency = 5
ReverseTunnel = yes
MaxClockSkew = 300
HA-FAauth = yes
MN-FAauth = yes
Challenge = no
[Pool 1]
Size = 4
[SPI 257]
ReplayMethod = none
[SPI 258]
ReplayMethod = none
[Address 10.1.1.1]
Type = node
SPI = 258
Type = node
SPI = 257
Pool = 1
Type = node
SPI = 258
Pool = 1
Type = agent
SPI = 257
