This section provides procedures to display IPv6 name service information.
Task |
Description |
For Instructions, Go to ... |
Display name service information for IPv6 |
Displays name service information for IPv6 by using the nslookup command. | |
Verify that DNS IPv6 PTR records are updated correctly |
Displays the PTR records for DNS IPv6 PTR records by using the nslookup command. Also uses the set q=PTR parameter. |
How to Verify That DNS IPv6 PTR Records Are Updated Correctly |
Display IPv6 information through NIS |
Displays the IPv6 information through NIS by using the ypmatch command. | |
Displays the IPv6 information through NIS+ by using the nismatch command. | |
Display IPv6 information independent of name service |
Displays the IPv6 information by using the getent command. |
In this procedure, you use the nslookup command to display IPv6 name service information.
On the command line, type the following command:
% /usr/sbin/nslookup |
The default server name and address appear, followed by the nslookup command angle bracket prompt.
To see information about a particular host, type the following commands at the angle bracket prompt:
>set q=any >host-name |
To see only AAAA records, type the following command at the angle bracket prompt:
>set q=AAAA |
Quit the command by typing exit.
% /usr/sbin/nslookup Default Server: space1999.Eng.apex.COM Address: 120.46.168.78 > set q=any > vallejo Server: space1999.Eng.apex.COM Address: 120.46.168.78 vallejo.ipv6.eng.apex.com IPv6 address = fec0::9256:a00:fe12:528 vallejo.ipv6.eng.apex.com IPv6 address = 2::9256:a00:fe12:528 > exit |
In this procedure, you use the nslookup command to display PTR records for DNS IPv6.
The default server name and address display, followed by the nslookup command angle bracket prompt.
To see the PTR records, type the following command at the angle bracket prompt:
>set q=PTR |
% /usr/sbin/nslookup Default Server: space1999.Eng.apex.COM Address: 120.46.168.78 > set q=PTR > 8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int 8.2.5.0.2.1.e.f.f.f.0.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0.ip6.int name = vallejo.ipv6.Eng.apex.COM ip6.int nameserver = space1999.Eng.apex.COM > exit |
In this procedure, you use the ypmatch command to display IPv6 information through NIS.
% ypmatch host-name ipnodes.byname |
The information about host-name displays.
% ypmatch vallejo ipnodes.byname fec0::9256:a00:20ff:fe12:528 vallejo 2::9256:a00:20ff:fe12:528 vallejo |
In this procedure, you use the nismatch command to display IPv6 information through NIS.
% nismatch host-name ipnodes.org-dir |
% nismatch vallejo ipnodes.org_dir vallejo vallejo fec0::9256:a00:20ff:fe12:528 vallejo vallejo 2::9256:a00:20ff:fe12:528 |
% getent ipnodes host-name |
% getent ipnodes vallejo 2::56:a00:fe87:9aba vallejo vallejo fec0::56:a00:fe87:9aba vallejo vallejo |
