System Administration Guide: IP Services
Enabling IPv6 Nodes Task Map
Table 15–1 Enabling IPv6 Nodes Task Map
Task
Description
For Instructions, Go to ...
Enable IPv6 on a node
Involves touching hostname6.interface file, displaying addresses, and entering the addresses in the /etc/inet/ipnodes file. (See note.)
How to Enable IPv6 on a Node
Configure a Solaris IPv6 router
Involves adding entries to the indp.conf file.
How to Configure a Solaris IPv6 Router
Add IPv6 addresses to NIS and NIS+
Involves adding entries to the /etc/ipnodes file.
How to Add IPv6 Addresses to NIS and NIS+
Add IPv6 addresses to DNS
Involves adding AAAA records to the DNS zone and reverse zone file.
How to Add IPv6 Addresses to DNS
Note –
You can enable IPv6 on a system when you install the Solaris software. If you answered yes to enable IPv6 during the installation process, you can omit the following procedures to enable IPv6.
