Task |
Description |
For Instructions, Go to ... |
Display name service information for IPv6 |
Displays name service information for IPv6 by using the nslookup command. | |
Verify that DNS IPv6 PTR records are updated correctly |
Displays the PTR records for DNS IPv6 PTR records by using the nslookup command. Also uses the set q=PTR parameter. |
How to Verify That DNS IPv6 PTR Records Are Updated Correctly |
Display IPv6 information through NIS |
Displays the IPv6 information through NIS by using the ypmatch command. | |
Displays the IPv6 information through NIS+ by using the nismatch command. | |
Display IPv6 information independent of name service |
Displays the IPv6 information by using the getent command. |
