Solaris PPP 4.0 includes the /etc/ppp/myisp-chat.tmpl, which you can modify for use at your site. /etc/ppp/myisp-chat.tmpl is similar to the basic modem chat script except that it does not include a login sequence.
ABORT BUSY ABORT 'NO CARRIER' REPORT CONNECT TIMEOUT 10 "" "AT&F1" OK "AT&C1&D2" SAY "Calling myisp\n" TIMEOUT 60 OK "ATDT1-123-555-1212" CONNECT \c |
Script Contents |
Explanation |
ABORT BUSY |
Abort transmission if the modem receives this message from the opposite peer. |
ABORT 'NO CARRIER |
Abort transmission if the modem reports ABORT 'NO CARRIER' when dialing. The cause for this message is usually a dialing or modem negotiation failure. |
REPORT CONNECT |
Gather the CONNECT string from the modem and print it out. |
TIMEOUT 10 |
Set initial timeout to 10 seconds. The modem's response should be immediate. |
"" "AT&F1" |
Reset the modem to factory defaults. |
OK "AT&C1&D2" |
Reset the modem so that, for &C1, DCD from the modem follows carrier. If the remote side hangs up the phone for some reason, then the DCD drops. For &D2, DTR high-to-low transition causes the modem to go on-hook (hang up). |
SAY "Calling myisp\n" |
Display the message “Calling myisp” on the local machine. |
TIMEOUT 60 |
Reset the timeout to 60 seconds to allow more time for link negotiation. |
OK "ATDT1-123-555-1212" |
Call the remote peer by using the phone number 123-555-1212. |
CONNECT \c |
Wait for the CONNECT message from the opposite peer's modem. |
