If the chat script that is needed for a particular peer is long or complicated, consider creating the script as a separate file. External chat files are easy to maintain and document. You can add comments to the chat file by preceding them with the hash (#) sign.
The procedure How to Create the Instructions for Calling a Peer shows the use of a chat script that is contained in an external file.
