System Administration Guide: Resource Management and Network Services
Using the mount Command
Both of these commands mount an NFS file system from the server bee read-only:
# mount -F nfs -r bee:/export/share/man /usr/man
# mount -F nfs -o ro bee:/export/share/man /usr/man
This command uses the -O option to force the man pages from the server bee to be mounted on the local system even if /usr/man has already been mounted as follows:
# mount -F nfs -O bee:/export/share/man /usr/man
This command uses client failover:
# mount -F nfs -r bee,wasp:/export/share/man /usr/man
Note –
When used from the command line, the listed servers must support the same version of the NFS protocol. Do not mix version 2 and version 3 servers when running mount from the command line. You can use mixed servers with autofs. Autofs automatically selects the best subset of version 2 or version 3 servers.
Here is an example of using an NFS URL with the mount command:
# mount -F nfs nfs://bee//export/share/man /usr/man
Use the mount command with no arguments to display file systems that are mounted on a client.
% mount
/ on /dev/dsk/c0t3d0s0 read/write/setuid on Tues Jan 24 13:20:47 1995
/usr on /dev/dsk/c0t3d0s6 read/write/setuid on Tues Jan 24 13:20:47 1995
/proc on /proc read/write/setuid on Tues Jan 24 13:20:47 1995
/dev/fd on fd read/write/setuid on Tues Jan 24 13:20:47 1995
/tmp on swap read/write on Tues Jan 24 13:20:51 1995
/opt on /dev/dsk/c0t3d0s5 setuid/read/write on Tues Jan 24 13:20:51 1995
/home/kathys on bee:/export/home/bee7/kathys
  intr/noquota/nosuid/remote on Tues Jan 24 13:22:13 1995
