By using client-side failover, an NFS client can switch to another server if the server that supports a replicated file system becomes unavailable. The file system can become unavailable if the server it is connected to crashes, if the server is overloaded, or if a network fault occurs. The failover, under these conditions, is normally transparent to the user. After it is established, the failover can occur at any time without disrupting the processes that are running on the client.
Failover requires that the file system be mounted read-only. The file systems must be identical for the failover to occur successfully. See What Is a Replicated File System? for a description of what makes a file system identical. A static file system or one that is not changed often is the best candidate for failover.
You cannot use file systems that are mounted by using CacheFS with failover. Extra information is stored for each CacheFS file system. This information cannot be updated during failover, so only one of these two features can be used when mounting a file system.
The number of replicas that need to be established for each file system depends on many factors. In general, the ideal is to have a minimum of two servers, with each supporting multiple subnets, rather than to have a unique server on each subnet. The process requires checking of each server in the list. Therefore, if more servers are listed, each mount will be slower.
To fully comprehend the process, you need to understand two terms.
failover – The process of selecting a server from a list of servers that support a replicated file system. Normally, the next server in the sorted list is used, unless it fails to respond.
remap – To making use of a new server. Through normal use, the clients store the path name for each active file on the remote file system. During the remap, these path names are evaluated to locate the files on the new server.
For the purposes of failover, a file system can be called a replica when each file is the same size and has the same vnode type as the original file system. Permissions, creation dates, and other file attributes are not considered. If the file size or vnode types are different, the remap fails and the process hangs until the old server becomes available.
You can maintain a replicated file system by using rdist, cpio, or another file transfer mechanism. Because updating the replicated file systems causes inconsistency, follow these suggestions for best results:
Rename the old version of the file before installing a new one.
Run the updates at night when client usage is low.
Keep the updates small.
Minimize the number of copies.
Some software packages require read locks on files. To prevent these products from breaking, read locks on read-only file systems are allowed, but are visible to the client side only. The locks persist through a remap because the server doesn't “know” about them. Because the files should not change, you do not need to lock the file on the server side.
