System Administration Guide: Resource Management and Network Services
Simple Autofs Mount
To help explain the autofs mount process, assume that the following files are installed.
$ cat /etc/auto_master
# Master map for automounter
+auto_master
/net        -hosts        -nosuid,nobrowse
/home       auto_home     -nobrowse
/xfn        -xfn
/share      auto_share
$ cat /etc/auto_share
# share directory map for automounter
ws          gumbo:/export/share/ws
When the /share directory is accessed, the autofs service creates a trigger node for /share/ws, which can be seen in /etc/mnttab as an entry that resembles the following entry:
-hosts  /share/ws     autofs  nosuid,nobrowse,ignore,nest,dev=###
When the /share/ws directory is accessed, the autofs service completes the process with these steps:
  1. Pings the server's mount service to see if it's alive.
  2. Mounts the requested file system under /share. Now /etc/mnttab file contains the following entries:
    gumbo:/export/share/ws /share/ws   nfs   nosuid,dev=####    #####
