System Administration Guide: Resource Management and Network Services
New Built-in Mailer Feature
The old [TCP] built-in mailer is not available. Use the P=[IPC] built-in mailer instead. The interprocess communications ([IPC]) built-in mailer now enables delivery to a UNIX domain socket on systems that support it. You can use this mailer with LMTP delivery agents that listen on a named socket. An example mailer might resemble the following.
Mexecmail, P=[IPC], F=lsDFMmnqSXzA5@/:|, E=\r\n,
S=10, R=20/40, T=DNS/RFC822/X-Unix, A=FILE /var/run/lmtpd
The first mailer argument in the [IPC] mailer is now checked for a legitimate value. The following table provides possible values for the first mailer argument.
Table 27–20 Possible Values for the First Mailer Argument
Value
Description
A=FILE
Use for UNIX domain socket delivery
A=TCP
Use for TCP/IP connections
A=IPC
Is no longer available as a first mailer argument
