System Administration Guide: Resource Management and Network Services
New MAX Macros
Use the following new macros to configure the maximum number of commands that can be received before sendmail slows its delivery. You can set these MAX macros at compile time. The maximum values in the following table also represent the current default values.
Table 27–12 New MAX Macros
Macro
Maximum Value
Commands Checked by Each Macro
MAXBADCOMMANDS
25
Unknown commands
MAXNOOPCOMMANDS
20
NOOP, VERB, ONEX, XUSR
MAXHELOCOMMANDS
3
HELO, EHLO
MAXVRFYCOMMANDS
6
VRFY, EXPN
MAXETRNCOMMANDS
8
ETRN
Note –
You can disable a macro's check by setting the macro's value to zero.
