System Administration Guide: Resource Management and Network Services
New Equates for Delivery Agents
The following table describes new equates that you can use with the M delivery agent definition command. The following syntax shows you how to append new equates or new arguments to the equates that already exist in the configuration file.
Magent_name, equate, equate, ...
The following example includes the new W= equate, which specifies the maximum time to wait for the mailer to return after all data has been sent.
Msmtp, P=[IPC], F=mDFMuX, S=11/31, R=21, E=\r\n, L=990, W=2m
When you modify the definition of a value for m4 configuration, use the syntax that is provided in the following example.
define(`SMTP_MAILER_MAXMSGS', `1000')
The preceding example places a limit of 1000 on the number of messages that are delivered per connection on an smtp mailer.
If you need to build a new sendmail.cf file, refer to Building the sendmail.cf Configuration File (Task) in Chapter 25, Mail Services (Tasks).
Note –
Typically, you modify the equate definitions in the mailer directory only when you fine-tune.
Table 27–17 New Equates for Delivery Agents
Equate
Description
Argument: Path to a directory
Specifies a directory to apply chroot() to before the mailer program is executed
m=
Argument: Any of the following m4 values that have previously been defined with the define() routine
    SMTP_MAILER_MAXMSGS, for the smtp mailer
    LOCAL_MAILER_MAXMSGS, for the local mailer
    RELAY_MAILER_MAXMSGS, for the relay mailer
Limits the number of messages that are delivered per connection on an smtp, local, or relay mailer
W=
Argument: An increment of time
Specifies the maximum time to wait for the return of the mailer after all data has been sent
