A default set of NIS maps are provided in the Solaris operating environment. You might want to use all these maps or only some of them. NIS can also use whatever maps you create or add when you install other software products.
Default maps for a NIS domain are located in each server's /var/yp/domainname directory. For example, the maps that belong to the domain test.com are located in each server's /var/yp/test.com directory.
Table 7–3 describes the default NIS maps, information they contain, and whether the software consults the corresponding administrative files when NIS is running.
Table 7–3 NIS Map Descriptions|
Map Name |
Corresponding NIS Admin File |
Description |
bootparams |
bootparams |
Contains path names of files clients need during boot: root, swap, possibly others. |
ethers.byaddr |
ethers |
Contains machine names and Ethernet addresses. The Ethernet address is the key in the map. |
ethers.byname |
ethers |
Same as ethers.byaddr, except the key is machine name instead of the Ethernet address. |
group.bygid |
group |
Contains group security information with group ID as key. |
group.byname |
group |
Contains group security information with group name as key. |
hosts.byaddr |
hosts |
Contains machine name, and IP address, with IP address as key. |
hosts.byname |
hosts |
Contains machine name and IP address, with machine (host) name as key. |
mail.aliases |
aliases |
Contains aliases and mail addresses, with aliases as key. |
mail.byaddr |
aliases |
Contains mail address and alias, with mail address as key. |
netgroup.byhost |
netgroup |
Contains group name, user name and machine name. |
netgroup.byuser |
netgroup |
Same as netgroup.byhost, except that key is user name. |
netgroup |
netgroup |
Same as netgroup.byhost, except that key is group name. |
netid.byname |
passwd, hosts group |
Used for UNIX-style authentication. Contains machine name and mail address (including domain name). If there is a netid file available it is consulted in addition to the data available through the other files. |
netmasks.byaddr |
netmasks |
Contains network mask to be used with IP submitting, with the address as key. |
networks.byaddr |
networks |
Contains names of networks known to your system and their IP addresses, with the address as key. |
networks.byname |
networks |
Same as networks.byaddr, except key is name of network. |
passwd.adjunct. byname |
passwd and shadow |
Contains auditing information and the hidden password information for C2 clients. |
passwd.byname |
passwd and shadow |
Contains password information with user name as key. |
passwd.byuid |
passwd and shadow |
Same as passwd.byname, except that key is user ID. |
protocols.byname |
protocols |
Contains network protocols known to your network. |
protocols.bynumber |
protocols |
Same as protocols.byname, except that key is protocol number. |
rpc.bynumber |
rpc |
Contains program number and name of RPCs known to your system. Key is RPC program number. |
services.byname |
services |
Lists Internet services known to your network. Key is port or protocol. |
services.byservice |
services |
Lists Internet services known to your network. Key is service name. |
ypservers |
N/A |
Lists NIS servers known to your network. |
New ipnodes maps (ipnodes.byaddr and ipnodes.byname) are added to NIS. The maps store both IPv4 and IPv6 addresses. See ipnodes(4). NIS clients and servers can communicate using either IPv4 or IPv6 RPC transports.
