Assume that a text file /var/yp/mymap.asc was created with an editor or a shell script on the master. You want to create an NIS map from this file and locate it in the homedomain subdirectory. To do this, type the following on the master server.
# cd /var/yp # makedbm mymap.asc homedomain/mymap
The mymap map now exists on the master server in the directory homedomain. To distribute the new map to slave servers run ypxfr.
