System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
RFC 2307 Network Information Service Schema
The LDAP servers must be configured to support the revised RFC 2307.
The nisSchema OID is 1.3.6.1.1. The RFC 2307 Attributes are the following.
( nisSchema.1.0 NAME 'uidNumber'
DESC 'An integer uniquely identifying a user in an
		administrative domain'
EQUALITY integerMatch SYNTAX 'INTEGER' SINGLE-VALUE )
( nisSchema.1.1 NAME 'gidNumber'
DESC 'An integer uniquely identifying a group in an
( nisSchema.1.2 NAME 'gecos'
DESC 'The GECOS field; the common name'
EQUALITY caseIgnoreIA5Match
SUBSTRINGS caseIgnoreIA5SubstringsMatch
SYNTAX 'IA5String' SINGLE-VALUE )
( nisSchema.1.3 NAME 'homeDirectory'
DESC 'The absolute path to the home directory'
EQUALITY caseExactIA5Match
( nisSchema.1.4 NAME 'loginShell'
DESC 'The path to the login shell'
( nisSchema.1.5 NAME 'shadowLastChange'
( nisSchema.1.6 NAME 'shadowMin'
( nisSchema.1.7 NAME 'shadowMax'
( nisSchema.1.8 NAME 'shadowWarning'
( nisSchema.1.9 NAME 'shadowInactive'
( nisSchema.1.10 NAME 'shadowExpire'
( nisSchema.1.11 NAME 'shadowFlag'
( nisSchema.1.12 NAME 'memberUid'
SUBSTRINGS caseExactIA5SubstringsMatch
SYNTAX 'IA5String' )
( nisSchema.1.13 NAME 'memberNisNetgroup'
( nisSchema.1.14 NAME 'nisNetgroupTriple'
DESC 'Netgroup triple'
SYNTAX 'nisNetgroupTripleSyntax' )
( nisSchema.1.15 NAME 'ipServicePort'
( nisSchema.1.16 NAME 'ipServiceProtocol'
SUP name )
( nisSchema.1.17 NAME 'ipProtocolNumber'
( nisSchema.1.18 NAME 'oncRpcNumber'
( nisSchema.1.19 NAME 'ipHostNumber'
DESC 'IP address as a dotted decimal, eg. 192.168.1.1
	     omitting leading zeros'
SUP name )
( nisSchema.1.20 NAME 'ipNetworkNumber'
DESC 'IP network as a dotted decimal, eg. 192.168,
SUP name SINGLE-VALUE )
( nisSchema.1.21 NAME 'ipNetmaskNumber'
DESC 'IP netmask as a dotted decimal, eg. 255.255.255.0,
SYNTAX 'IA5String{128}' SINGLE-VALUE )
( nisSchema.1.22 NAME 'macAddress'
DESC 'MAC address in maximal, colon separated hex
      notation, eg. 00:00:92:90:ee:e2'
SYNTAX 'IA5String{128}' )
( nisSchema.1.23 NAME 'bootParameter'
DESC 'rpc.bootparamd parameter'
SYNTAX 'bootParameterSyntax' )
( nisSchema.1.24 NAME 'bootFile'
DESC 'Boot image name'
( nisSchema.1.26 NAME 'nisMapName'
SUP name )
( nisSchema.1.27 NAME 'nisMapEntry'
SYNTAX 'IA5String{1024}' SINGLE-VALUE )
( nisSchema.1.28 NAME 'nisPublicKey'
DESC 'NIS public key'
SYNTAX 'nisPublicKeySyntax' )
( nisSchema.1.29 NAME 'nisSecretKey'
DESC 'NIS secret key'
SYNTAX 'nisSecretKeySyntax' )
( nisSchema.1.30 NAME 'nisDomain'
DESC 'NIS domain'
( nisSchema.1.31 NAME 'automountMapName'
DESC 'automount Map Name'
SUBSTR caseExactIA5SubstringsMatch
SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE )
( nisSchema.1.32 NAME 'automountKey'
DESC 'Automount Key value'
( nisSchema.1.33 NAME 'automountInformation'
DESC 'Automount information'
The nisSchema OID is 1.3.6.1.1. The RFC 2307 objectClasses are the following.
( nisSchema.2.0 NAME 'posixAccount' SUP top AUXILIARY
  DESC 'Abstraction of an account with POSIX attributes'
  MUST ( cn $ uid $ uidNumber $ gidNumber $ homeDirectory )
  MAY ( userPassword $ loginShell $ gecos $ description ) )
( nisSchema.2.1 NAME 'shadowAccount' SUP top AUXILIARY
  DESC 'Additional attributes for shadow passwords'
  MUST uid
  MAY ( userPassword $ shadowLastChange $ shadowMin
        shadowMax $ shadowWarning $ shadowInactive $
        shadowExpire $ shadowFlag $ description ) )
( nisSchema.2.2 NAME 'posixGroup' SUP top STRUCTURAL
  DESC 'Abstraction of a group of accounts'
  MUST ( cn $ gidNumber )
  MAY ( userPassword $ memberUid $ description ) )
( nisSchema.2.3 NAME 'ipService' SUP top STRUCTURAL
  DESC 'Abstraction an Internet Protocol service.
        Maps an IP port and protocol (such as tcp or udp)
        to one or more names; the distinguished value of
        the cn attribute denotes the service's canonical
        name'
  MUST ( cn $ ipServicePort $ ipServiceProtocol )
  MAY ( description ) )
( nisSchema.2.4 NAME 'ipProtocol' SUP top STRUCTURAL
  DESC 'Abstraction of an IP protocol. Maps a protocol number
        to one or more names. The distinguished value of the cn
        attribute denotes the protocol's canonical name'
  MUST ( cn $ ipProtocolNumber )
  MAY  description )
( nisSchema.2.5 NAME 'oncRpc' SUP top STRUCTURAL
  DESC 'Abstraction of an Open Network Computing (ONC)
        [RFC1057] Remote Procedure Call (RPC) binding.
        This class maps an ONC RPC number to a name.
        The distinguished value of the cn attribute denotes
        the RPC service's canonical name'
  MUST ( cn $ oncRpcNumber $ description )
  MAY  description )
( nisSchema.2.6 NAME 'ipHost' SUP top AUXILIARY
  DESC 'Abstraction of a host, an IP device. The distinguished
        value of the cn attribute denotes the host's canonical
        name. Device SHOULD be used as a structural class'
  MUST ( cn $ ipHostNumber )
  MAY ( l $ description $ manager $ userPassword ) )
( nisSchema.2.7 NAME 'ipNetwork' SUP top STRUCTURAL
  DESC 'Abstraction of a network. The distinguished value of
        the cn attribute denotes the network's canonical name'
  MUST ipNetworkNumber
  MAY ( cn $ ipNetmaskNumber $ l $ description $ manager ) )
( nisSchema.2.8 NAME 'nisNetgroup' SUP top STRUCTURAL
  DESC 'Abstraction of a netgroup. May refer to other netgroups'
  MUST cn
  MAY ( nisNetgroupTriple $ memberNisNetgroup $ description ) )
( nisSchema.2.9 NAME 'nisMap' SUP top STRUCTURAL
  DESC 'A generic abstraction of a NIS map'
  MUST nisMapName
  MAY description )
( nisSchema.2.10 NAME 'nisObject' SUP top STRUCTURAL
  DESC 'An entry in a NIS map'
  MUST ( cn $ nisMapEntry $ nisMapName )
  MAY description )
( nisSchema.2.11 NAME 'ieee802Device' SUP top AUXILIARY
  DESC 'A device with a MAC address; device SHOULD be
  MAY macAddress )
( nisSchema.2.12 NAME 'bootableDevice' SUP top AUXILIARY
  DESC 'A device with boot parameters; device SHOULD be
  MAY ( bootFile $ bootParameter ) )
( nisSchema.2.14 NAME 'nisKeyObject' SUP top AUXILIARY
  DESC 'An object with a public and secret key'
  MUST ( cn $ nisPublicKey $ nisSecretKey )
  MAY ( uidNumber $ description ) )
( nisSchema.2.15 NAME 'nisDomainObject' SUP top AUXILIARY
  DESC 'Associates a NIS domain with a naming context'
  MUST nisDomain )
( nisSchema.2.16 NAME 'automountMap' SUP top STRUCTURAL
  MUST ( automountMapName )
  MAY description )
( nisSchema.2.17 NAME 'automount' SUP top STRUCTURAL
  MUST ( automountKey $ automountInformation )
  MAY description )
