System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Start-of-Authority record (SOA)
Example 5–19 shows the syntax of a start-of-authority (SOA) resource record.
Example 5–19 SOA Record Format
name class SOA origin person-in-charge ( serial number
	 refresh
 retry
 expire
 ttl)
The SOA record designates the start of a zone. The zone ends at the next SOA record. The SOA record fields are described below.
name
This field indicates the name of the zone. Note that the zone name must end with a trailing dot. For example: doc.com. is correct, while doc.com is wrong.
class
This field is the address class. For example, IN for Internet (the most commonly used class).
SOA
This field is the type of this resource record.
origin
This field is the name of the host where this data file resides. Note that this host name must end in a trailing dot. For example, dnsmaster.doc.com. is correct, but dnsmaster.doc.com is wrong.
person-in-charge
This field is the email address of the person responsible for the name server. For example, kjd.nismaster.doc.com. Again, this name must end with a trailing dot.
serial
This field is the version number of this data file. You must increment this number whenever you make a change to the data: slave servers use the serial field to detect whether the data file has been changed since the last time they copied the file from the master server.
refresh
This field indicates how often, in seconds, a slave name server should check with the master name server to see if an update is needed. For example, 7200 indicates a period of two hours.
retry
This field indicates how long, in seconds, a slave server is to retry after a failure to check for a refresh.
expire
This field is the upper limit, in seconds, that a slave name server is to use the data before it expires for lack of getting a refresh.
ttl
This field is the default number of seconds to be used for the time-to-live field on resource records that do not have a ttl specified elsewhere.
There should only be one SOA record per zone. Example 5–20 is a sample SOA resource record.
Example 5–20 Sample SOA Resource Record
;name class 		SOA 	origin				 person-in-charge
doc.com. IN		SOA	dnsmaster.doc.com. root.nismaster.doc.com. (
							101			;Serial
							7200		;Refresh
							3600		;Retry
							432000		;Expire
							86400)		;Minimum			 )
