Example 5–23 shows the syntax of an address (A) resource record:
machinename [optional TTL] class A address |
The A record lists the address for a given machine. The name field is the host name, and the address is the IP address. One A record should exist for each address of the machine (in other words, routers, or gateways require at least two entries, a separate entry including the IP address assigned to each network interface).
;machinename [TTL] class A address sirius IN A 123.45.6.1 |
