System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Mail Exchanger (MX)
Example 5–33 shows the syntax for a mail-exchanger (MX) resource record.
Example 5–33 MX Record Format
name [optional TTL] class	MX preference-value mailer-exchanger
The MX resource records are used to specify a machine that knows how to deliver mail to a domain or specific machines in a domain. There might be more than one MX resource record for a given name. In Example 5–34, Seismo.CSS.GOV. (note the fully qualified domain name) is a mail gateway that knows how to deliver mail to Munnari.OZ.AU. Other machines on the network cannot deliver mail directly to Munnari. Seismo and Munnari might have a private connection or use a different transport medium. The preference-value field indicates the order a mailer should follow when there is more than one way to deliver mail to a single machine. The value 0 (zero) indicates the highest preference. If there is more than one MX resource record for the same name, records might or might not have the same preference value.
You can use names with the wildcard asterisk (*) for mail routing with MX records. There are likely to be servers on the network that state that any mail to a domain is to be routed through a relay. In Example 5–34, all mail to hosts in domain foo.com is routed through RELAY.CS.NET. You do this by creating a wildcard resource record, which states that the mail exchanger for *.foo.com is RELAY.CS.NET. The asterisk will match any host or subdomain of foo.com, but it will not match foo.com itself.
Example 5–34 Sample MX Resource Record
;name	 	[TTL]	class		MX	 preference mailer-exchanger
Munnari.OZ.AU.		IN		MX	 0	Seismo.CSS.GOV.
foo.com.		IN		MX	 10	RELAY.CS.NET.
*.foo.com.		IN		MX	 20	RELAY.CS.NET.
