System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
A Practical Example
This section shows the files you need to implement DNS for a sample Internet-connected network, based on the examples used in this chapter.
Caution – Caution –
The IP addresses and network numbers used in examples and code samples in this manual are for illustration purposes only. Do not use them as shown because they might have been assigned to an actual network or host.
This example assumes the following.
Table 5–1 Example Network Domain and Zone Configuration
Name and Zone
Number
doc.com
123.45.6
sales.doc.com
111.22.3
Table 5–2 Example Network DNS Servers
Zone
Host Name
Function
Address
 CNAME
doc.com
sirius
master for doc.com
123.45.6.1
dnsmaster
doc.com
deneb
slave for doc.com
111.22.3.5
dnssecond
sales.doc.com
altair
master for sales.doc.com
111.22.3.4
dnssales
sales.doc.com
altair
slave for sales.doc.com
123.45.6.1
dnsmaster
Example Boot Files
The following code examples show boot files for the three servers in the two networks:
Example 5–1 Example Boot File for dnsmastr Server
; named.boot file on the dnsmastr (sirius)
; files required by in.named are located here
directory /var/named
; here are the names of the master files
cache         .                         named.ca
master       doc.com                   db.doc
master       0.0.127.in-addr.arpa      named.local
master       6.45.123.in-addr.arpa     doc.rev
;This system is also the slave for the sales.doc.com domain
slave     sales.doc.com             111.22.3.4   db.sales
slave     3.22.111.in-addr.arpa     111.22.3.4   sales.rev
Example 5–2 Example Boot File for dnssales Server
; named.boot file on the dnssales (altair)
; in.named is located here
cache      .                        named.ca
master    sales.doc.com            db.sales
master    0.0.127.in-addr.arpa     db.127.0.0
master    3.22.111.in-addr.arpa    db.192.168.8
Example 5–3 Example Boot File for dnssecond Server
; named.boot file on the dnsecond (deneb)
cache           .               named.ca
slave       doc.com         123.45.6.1 doc.com
slave       6.45.123.in-addr.arpa    123.45.6.1 doc.123.45.6
Example resolv.conf Files
The following code examples show resolv.conf files for the three servers in the two networks. (If the host in question is not running in.named, the local host address should not be used as a name server.)
Example 5–4 Example resolve.conf File for dnsmastr Server
; /etc/resolv.conf file for dnsmaster (sirius)
domain           doc.com
nameserver       0.0.0.0
nameserver       111.22.3.5
Example 5–5 Example resolve.conf File for dnssales Server
; /etc/resolv.conf file for dnssales (altair)
domain           sales.doc.com
nameserver       111.22.3.4
nameserver       123.45.6.1
Example 5–6 Example resolve.conf File for dnssecond Server
; /etc/resolv.conf for dnssecond
domain           doc.com
Example named.local File
The following code example shows the named.local file used by the two master servers on the two networks. Both servers have the same file.
Example 5–7 Example named.local File for Both master Servers
; SOA rec
0.0.127.in-addr.arpa. IN SOA siriusdoc.com. sysop.centauri.doc.com.(
                          19970331    ; serial number
                          10800       ; refresh every 3 hours
                          10800       ; retry every 3 hours
                          604800      ; expire after a week
                          86400 )     ; TTL of 1 day
; Name Servers
0.0.127.in-addr.arpa.  IN  NS   sirius.doc.com.
0.0.127.in_addr.arpa   IN  NS   dnssecond.doc.com
1  IN  PTR localhost.
Example hosts Files
The following code examples show db.doc and db.sales files for the two master servers on the two networks.
Example 5–8 Example db.doc File for dnsmastr server
; SOA rec
doc.com. IN SOA sirius.doc.com. sysop.centauri.doc.com. (
                          19970332    ; serial number
; Name Servers
doc.com.               IN  NS  sirius.doc.com.
sales.doc.com.         IN  NS  altair.sales.doc.com.
; Addresses
localhost              IN  A  127.0.0.1
sirius                 IN  A  123.45.6.1
rigel                  IN  A  123.45.6.112
antares                IN  A  123.45.6.90
polaris                IN  A  123.45.6.101
procyon                IN  A  123.45.6.79
tauceti                IN  A  123.45.6.69
altair.sales.doc.com.   N  A   111.22.3.4
; aliases
dnsmastr               IN  CNAME    sirius.doc.com.
dnssecond.doc.com      IN  CNAME   deneb.doc.com
Example 5–9 Example db.sales File for dnssales server
; SOA rec
sales.doc.com.  IN SOA altair.sales.doc.com. sysop.polaris.doc.com. (
; Name Servers
; Addresses
altair                  IN  A  111.22.3.4
sirius.doc.com.         IN  A  123.45.6.1
luna                    IN  A  192.168.8.22
phoebus                 IN  A  192.168.8.24
deimos                  IN  A  192.168.8.25
ganymede                IN  A  192.168.8.27
europa                  IN  A  192.168.8.28
callisto                IN  A  192.168.8.29
; aliases
dnssales.sales.doc.com  IN  CNAME    altair.sales.doc.com
Example hosts.rev Files
The following code examples show hosts.rev files for the two master servers on the two networks:
Example 5–10 Example doc.rev File for dnsmastr server
; SOA rec
6.45.123.in-addr.arpa.  IN SOA sirius.doc.com. sysop.centauri.doc.com. (
; Name Servers
6.45.123.in-addr.arpa.  IN  NS  sirius.doc.com.
;Pointer records for 123.45.6
1                       IN  PTR sirius.doc.com.
112                     IN  PTR rigel.doc.com.
90                      IN  PTR antares.doc.com.
101                     IN  PTR polaris.doc.com.
79                      IN  PTR procyon.doc.com.
69                      IN  PTR tauceti.doc.com.
Example 5–11 Example hosts.rev File for dnssales Server
; SOA rec
3.22.111.in-addr.arpa.  IN SOA altair.sales.doc.com. \
sysop.polaris.doc.com.(
; Name Servers
3.22.111.in-addr.arpa.  IN  NS  altair.sales.doc.com.; \
Pointer records for 111.22.3
22                      IN  PTR  luna
23                      IN  PTR  deneb
24                      IN  PTR  phoebus
25                      IN  PTR  deimos
26                      IN  PTR  altair
27                      IN  PTR  ganymede
28                      IN  PTR  europa
29                      IN  PTR  callisto
Example name.ca File
The following code example shows the named.ca file that is stored on each of the two master servers on the two networks. Both servers use identical named.ca files.
Example 5–12 Example named.ca File
; formerly NS1.ISI.EDU
.                        3600000      NS    B.ROOT-SERVERS.NET.
B.ROOT-SERVERS.NET.      3600000      A     128.9.0.107
; formerly C.PSI.NET
.                        3600000      NS    C.ROOT-SERVERS.NET.
C.ROOT-SERVERS.NET.      3600000      A     192.33.4.12
; formerly TERP.UMD.EDU
.                        3600000      NS    D.ROOT-SERVERS.NET.
D.ROOT-SERVERS.NET.      3600000      A     128.8.10.90
; formerly NS.NASA.GOV
;.                       3600000      NS    E.ROOT-SERVERS.NET.
E.ROOT-SERVERS.NET.      3600000      A     192.203.230.10
; formerly NS.ISC.ORG
.                        3600000      NS    F.ROOT-SERVERS.NET.
F.ROOT-SERVERS.NET.      3600000      A     192.5.5.241
; formerly NS.NIC.DDN.MIL
.                        3600000      NS    G.ROOT-SERVERS.NET.
G.ROOT-SERVERS.NET.      3600000      A     192.112.36.4
; formerly AOS.ARL.ARMY.MIL
.                        3600000      NS    H.ROOT-SERVERS.NET.
H.ROOT-SERVERS.NET.      3600000      A     128.63.2.53
; formerly NIC.NORDU.NET
.                        3600000      NS    I.ROOT-SERVERS.NET.
I.ROOT-SERVERS.NET.      3600000      A     192.36.148.17
; temporarily housed at NSI (InterNIC)
.                        3600000      NS    J.ROOT-SERVERS.NET.
J.ROOT-SERVERS.NET.      3600000      A     198.41.0.10
.                        3600000      NS    K.ROOT-SERVERS.NET.
K.ROOT-SERVERS.NET.      3600000      A     198.41.0.11
; temporarily housed at ISI (IANA)
.                        3600000      NS    L.ROOT-SERVERS.NET.
L.ROOT-SERVERS.NET.      3600000      A     198.32.64.12
.                        3600000      NS    M.ROOT-SERVERS.NET.
M.ROOT-SERVERS.NET.      3600000      A     198.32.65.12
; End of File
