System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
SSDs
The serviceSearchDescriptor attribute defines how and where an LDAP naming service client should search for information for a particular service. The serviceSearchDescriptor contains a service name, followed by one or more semicolon-separated base-scope-filter triples. These base-scope-filter triples are used to define searches only for the specific service and are searched in order. If multiple base-scope-filters are specified for a given service, then when that service looks for a particular entry, it will search in each base with the specified scope and filter.
Note –
Note that the default location is not searched for a service (database) with a SSD unless it is included in the SSD. Unpredictable behavior will result if multiple SSDs are given to a service.
In the following example, the Solaris LDAP naming service client performs a one level search in ou=west,dc=example,dc=com followed by a one level search in ou=east,dc=example,dc=com for the passwd service. To lookup the passwd data for a user's username, the default LDAP filter (&(objectClass=posixAccount)(uid=username)) is used for each BaseDN.
serviceSearchDescriptor: passwd:ou=west,dc=example,dc=com;ou=east,
dc=example,dc=com
In the following example, the Solaris LDAP naming service client would perform a subtree search in ou=west,dc=example,dc=com for the passwd service. To lookup the passwd data for user username, the subtree ou=west,dc=example,dc=com would be searched with the LDAP filter (&(fulltimeEmployee=TRUE)(uid=username)).
dc=com?sub?fulltimeEmployee=TRUE
It is also possible to associate multiple container with a particular service type.
For example, the service search descriptor
defaultSearchBase: dc=example,dc=com
serviceSearchDescriptor: \
passwd:ou=myuser;ou=newuser,ou=extuser,dc=example,dc=com
specifies that the three containers, ou=myuser,dc=example,dc=com, ou=newuser,dc=example,dc=com, and ou=extuser,dc=example,dc=com are searched for the password entries. Note that a trailing ',' implies that the defaultSearchBase is appended to the relative base in the SSD.
Attribute Map
The Solaris LDAP naming service allows one or more attribute names to be remapped for any of its services. (The Solaris LDAP client uses the well-known attributes documented in Chapter 18, General Reference.) If you map an attribute, you must be sure that the attribute has the same meaning and syntax as the original attribute. Note that mapping the userPassword attribute may cause problems.
There are a couple of reasons you might want to use schema mappings.
The format is service:attribute-name=mapped-attribute-name.
If you wish to map more than one attribute for a given service, you can define multiple attributeMap attributes.
In the following example, the employeeName and home attributes would be used whenever the uid and homeDirectory attributes would be for the passwd service.
attributeMap: passwd:uid=employeeName
attributeMap: passwd:homeDirectory=home
There exists one special case where you can map the passwd service's gecos attribute to several attributes. The following is an example.
attributemap: gecos=cn sn title
The above maps the gecos values to a space-separated list of the cn, sn and title attribute values.
objectClass Map
The Solaris LDAP naming service allows object classes to be remapped for any of its services. If you wish to map more than one object class for a given service, you can define multiple objectclassMap attributes. In the following example, the myUnixAccount object class is used whenever the posixAccount object class is used.
objectclassMap: passwd:posixAccount=myUnixAccount
