LDAP command line tools support a common set of options, including authentication and bind parameters.
These commands can be used to manipulate directory entries directly. The ldapsearch, ldapadd, and ldapmodify tools support a common text-based format for representing directory information called the LDAP Data Interchange Format (LDIF).
Table 18–3 LDAP Tools|
Tool |
Function |
Use to search for directory entries in the namespace. Displays attributes and values found. |
Use to modify, or add directory entry. |
Use to add new directory entry. |
Use to delete existing directory entry. |
