System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Setting Up SSDs Using idsconfig
Assume your predecessor at Example, Inc. had configured LDAP, storing users in ou=Users container. You are now upgrading to Solaris 9. By definition, Solaris 9 LDAP assumes that user entries are stored in ou=People container. Thus, when it comes to searching the passwd service, LDAP will search the ou=people level of the DIT and not find the correct values.
One rather laborious solution to the above problem would be to completely overwrite Example, Inc.'s existing DIT and to rewrite all the exiting applications on Example, Inc.'s network so that they are compatible with the new LDAP naming service. A second, far preferable solution would be to use an SSD that would tell LDAP to look for user info in an ou=Users container instead the default ou=people container.
You would define the necessary SSD during the configuration of the iPlanet Directory Server 5.1 using idsconfig. The prompt line appears as follows.
Do you wish to setup Service Search Descriptors (y/n/h? y
 A  Add a Service Search Descriptor
  D  Delete a SSD
  M  Modify a SSD
  P  Display all SSD's
  H  Help
  X  Clear all SSD's
  Q  Exit menu
Enter menu choice: [Quit] a
Enter the service id: passwd
Enter the base: service ou=user,dc=west,dc=example,dc=com
Enter the scope: one[default]
  D  Delete a SSD
  M  Modify a SSD
  P  Display all SSD's
  H  Help
  X  Clear all SSD's
  Q  Exit menu
Enter menu choice: [Quit] p
Current Service Search Descriptors:
Passwd:ou=Users,ou=west,ou=example,ou=com?
Hit return to continue.
  D  Delete a SSD
  M  Modify a SSD
  P  Display all SSD's
  H  Help
  X  Clear all SSD's
  Q  Exit menu
Enter menu choice: [Quit] q
