To add printer entries into the LDAP directory use either the printmgr configuration tool or the lpset -n ldap command-line utility See lpset(1M). Note that the printer objects added to the directory only define the connection parameter, required by print system clients, of printers. Local print server configuration data is still held in files. A typical printer entry would look like the following.
printer-uri=myprinter,ou=printers,dc=mkg,dc=example,dc=com objectclass=top objectclass=printerService objectclass=printerAbstract objectclass=sunPrinter printer-name=myprinter sun-printer-bsdaddr=printsvr.example.com,myprinter,Solaris sun-printer-kvp=description=HP LaserJet (PS) printer-uri=myprinter |
