The acl token records information about Access Control Lists. This token consists of four fixed fields. The fixed fields are:
a token ID that identifies this token as an acl token
a field that specifies the ACL type
an ACL ID field
a field that lists the permissions associated with this ACL
The praudit command displays the acl token as follows:
acl,tpanero,staff,0755 |
The acl token format is as follows:
