System Administration Guide: Security Services
exec_args Token
The exec_args token records the arguments to an exec() system call. The exec_args token has two fixed fields:
The remainder of this token is composed of zero or more null-terminated strings. The praudit command displays the exec_args token as follows:
vi,/etc/security/audit_user
The following figure shows the format of an exec_args token.
Figure 25–8 exec_args Token Format
The preceding context describes the graphic.
Note –
The exec_args token is output only when the audit policy argv is active.
