This token has been replaced by the newgroups token, which provides the same type of information but requires less space. A description of the groups token is provided here for completeness, but the application designer should use the newgroups token. Notice that praudit does not distinguish between the two tokens, as both token IDs are labelled groups when ASCII output is displayed.
The groups token records the groups entries from the process's credential. The groups token has two fixed fields:
A token ID that identifies this token as a groups token
An array of groups entries of size NGROUPS_MAX (16)
The remainder of the token consists of zero or more group entries. The praudit command displays the group token as follows:
group,staff,admin,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1 |
The following figure shows the format of a groups token.
The groups token is output only when the audit policy group is active.
