The path token contains access path information for an object. This token contains the following fields:
a token ID that identifies this token as an path token
a byte count of the path length
the absolute path to the object that is based on the real root of the system
The praudit command displays the path token as follows. Note that the path length field is not displayed.
path,/etc/security/audit_user |
The following figure shows the format of a path token.
