Each audit file is a self-contained collection of records. The file's name identifies the time span during which the records were generated and the machine that generated them.
Audit files that are complete have names of the following form:
start-time.finish-time.machine |
where start-time is the time that the first audit record in the audit file was generated, finish-time is the time that the last record was written to the file, and machine is the name of the machine that generated the file. For an example of these names, see Example of a Closed Audit File Name.
An audit log file that is still active has a name of the following form:
start-time.not_terminated.machine |
The file name time stamps are used by the auditreduce command to locate files that contain records for the specific time range that has been requested. These time stamps are important because there can be a month's accumulation or more of audit files online, and searching them all for records that were generated in the last 24 hours would be unacceptably expensive.
The start-time and end-time are timestamps with one-second resolution. They are specified in Greenwich Mean Time (GMT). The format is four digits for the year, followed by two digits for each month, day, hour, minute, and second, as follows:
YYYYMMDDHHMMSS |
The timestamps are in GMT to ensure that they will sort in proper order even across a daylight savings time boundary. Because they are in GMT, the date and hour must be translated to the current time zone to be meaningful. Beware of this point whenever you manipulate these files with standard file commands rather than with the auditreduce command.
The format of a file name of a still-active file is as follows:
YYYYMMDDHHMMSS.not_terminated.machine |
Here is an example:
19990327225243.not_terminated.dopey |
The audit log files are named by the beginning date. So, in the example above the audit file was created in 1999, on March 27, at 10:52:43 p.m, GMT. The not_terminated in the file name means either that the file is still active or that the auditd daemon was unexpectedly interrupted. The name dopey at the end is the host name of the machine whose audit data is being collected.
The format of the name of a closed audit log file is as follows:
YYYYMMDDHHMMSS.YYYYMMDDHHMMSS.hostname |
Here is an example:
19990320005243.19900327225351.dopey |
In this example, the audit log file was created in 1999, on March 20, at 12:52:43 a.m., GMT. The file was closed March 27, at 10:53:51 p.m., GMT. The name dopey at the end is the host name of the machine whose audit data was collected.
Whenever auditd is unexpectedly interrupted, the audit file that is open at the time retains the not_terminated file name designation. Also, when a machine is writing to a remotely mounted audit file and the file server crashes or becomes inaccessible, the not_terminated designation remains in the current file's name. The audit daemon opens a new audit file and keeps the old audit file name intact.
