The default PAM configuration file includes entries for the authentication service, account management, session management, and password management modules.
For the authentication module, the new entries are created for rlogin, login, and dtlogin if SEAM 1.0 or 1.0.1 are installed. An example of these entries follows. All these services use the new PAM library, /usr/lib/security/pam_krb5.so.1, to provide Kerberos authentication.
These entries use the try_first_pass option, which requests authentication by using the user's initial password. Using the initial password means that the user is not prompted for another password, even if multiple mechanisms are listed.
# cat /etc/pam.conf . . rlogin auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass login auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass dtlogin auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass other auth optional /usr/lib/security/pam_krb5.so.1 try_first_pass |
For the account management module, dtlogin has a new entry that uses the Kerberos library, as follows. An other entry is included to provide a default rule. Currently, no actions are taken by the other entry.
dtlogin account optional /usr/lib/security/pam_krb5.so.1 other account optional /usr/lib/security/pam_krb5.so.1 |
The last two entries in the /etc/pam.conf file are shown next. The other entry for session management destroys user credentials. The new other entry for password management selects the Kerberos library.
other session optional /usr/lib/security/pam_krb5.so.1 other password optional /usr/lib/security/pam_krb5.so.1 try_first_pass |
