The /usr/aset/asetenv file has two main sections:
A user-configurable environment variables section
An internal environment variables section
You can alter the user-configurable parameters section. However, the settings in the internal environment variables section are for internal use only and should not be modified.
You can edit the entries in the user-configurable section to do the following:
Choose which tasks to run
Specify the directories for the system files checks task
Schedule ASET execution
Specify a UID aliases file
Extend checks to NIS+ tables
