ASET uses the three master tune files, tune.low, tune.med, and tune.high, to ease or tighten access to critical system files. These master files are located in the /usr/aset/masters directory, and they can be modified to suit your environment. For additional information, see Tune Files.
The tune.low file sets permissions to values that are appropriate for default system settings. The tune.med file further restricts these permissions and includes entries that are not present in tune.low. The tune.high file restricts permissions even further.
Modify settings in the tune files by adding or deleting file entries. Setting a permission to a less restrictive value than the current setting has no effect. The ASET tasks do not relax permissions unless you downgrade your system security to a lower level.
