System Administration Guide: Security Services
PERIODIC_SCHEDULE Environment Variable
The value of PERIODIC_SCHEDULE follows the same format as the crontab file. Specify the variable value as a string of five fields enclosed in double quotation marks, with each field separated by a space:
"minutes hours day-of-month month day-of-week"
Table 20–3 Periodic_Schedule Variable Values
Variable
Value
minutes hours
Specifies start time in number of minutes (0–59) after the hour and the hour (0–23)
day-of-month
Specifies the day of the month when ASET should be run, with values from 1–31
month
Specifies the month of the year when ASET should be run, with values from 1–12
day-of-week
Specifies the day of the week when ASET should be run, with values from 0–6; Sunday is day 0
The following rules apply:
The default entry for the PERIODIC_SCHEDULE variable causes ASET to execute at 12:00 midnight every day:
PERIODIC_SCHEDULE=”0 0 * * *”
