When users log in to a system, they must enter both a user name and a password. Although logins are publicly known, passwords must be kept secret, known only to each user. You should ask your users to choose their passwords carefully, and they should change them often.
Passwords are initially created when you set up a user account. To maintain security on user accounts, you can set up password aging to force users to routinely change their passwords. You can also disable a user account by locking the password. For detailed information about setting up and maintaining passwords, see “Managing User Accounts and Groups (Overview)” in System Administration Guide: Basic Administration and the passwd(1) man page.
If your network uses NIS+, the password information is kept in the NIS+ database. Information in the NIS+ database can be protected by restricting access to authorized users. You can use the passwd command to change a user's NIS+ password.
If your network uses NIS, the password information is kept in the NIS password map. NIS does not support password aging. You can use the passwd command to change a user's NIS password.
If your network uses /etc files, the password information is kept in the system's /etc/passwd and /etc/shadow files. The user name and other information are kept in the password file /etc/passwd, while the encrypted password itself is kept in a separate shadow file, /etc/shadow. This security measure prevents a user from gaining access to the encrypted passwords. While the /etc/passwd file is available to anyone who can log in to a machine, only superuser can read the /etc/shadow file. You can use the passwd command to change a user's password on a local system.
If your network uses LDAP, the password and shadow information is stored in the ou=people container of the LDAP directory tree. You can use the password -r ldap command to change a user's LDAP password.
