Your system requires a root password for superuser mode. In the default configuration, a user cannot remotely log in to a system as root. When logging in remotely, a user must log in as himself or herself and then use the su command to become root. This setup enables you to track who is using superuser privileges on your system.
You have to use the su command to change to another user, for example, if you want to become superuser. For security reasons, you can monitor who has been using the su command, especially those users who are trying to gain superuser access.
For detailed instructions, see How to Monitor Who Is Using the su Command.
