No predefined roles are shipped with the Solaris 9 software. Management at a customer site must decide what types of roles should be set up. However, three recommended roles can be readily configured by assigning the appropriate predefined rights profile to the corresponding roles:
Primary Administrator rights profile – For creating a role that can perform all administrative tasks, granting rights to others, and editing rights that are associated with administrative roles. A user in this role can assign the Primary Administrator role and the ability to grant rights to other users.
System Administrator rights profile – For creating a role that can perform most nonsecurity administrative tasks. For example, the System Administrator can add new user accounts, but cannot set passwords or grant rights to other users.
Operator rights profile – For creating a role that can perform simple administrative tasks, such as backup and restore, and printer maintenance.
These rights profiles enable administrators to configure the suggested roles by using a single rights profile instead of having to mix and match rights profiles.
Those sites that customize roles should closely check the order of the rights profiles that are assigned to the role. The system does not prevent someone from typing multiple occurrences of the same command. The attributes that are assigned to the first occurrence of a command in a rights profile take precedence and all subsequent occurrences are ignored.
You can also set up root as a role through a manual process. This method prevents users from logging in directly as root, forcing them to log in as themselves first. See Making Root a Role.
