This section provides an alphabetical list (A-M) of common error messages for the SEAM commands, SEAM daemons, PAM framework, GSS interface, the NFS service, and the Kerberos library.
major_error minor_error gssapi error importing name
An error occurred while a service name was being imported.
Solution:Make sure that the service principal is in the host's keytab file.
Bad krb5 admin server hostname while initializing kadmin interface
An invalid host name is configured for admin_server in the krb5.conf file.
Solution:Make sure that the correct host name for the master KDC is specified on the admin_server line in the krb5.conf file.
Cannot contact any KDC for requested realm
No KDC responded in the requested realm.
Solution:Make sure that at least one KDC (either the master or slave) is reachable or that the krb5kdc daemon is running on the KDCs. Check the /etc/krb5/krb5.conf file for the list of configured KDCs (kdc = kdc_name).
Cannot determine realm for host
Kerberos cannot determine the realm name for the host.
Solution:Make sure that there is a default realm name, or that the domain name mappings are set up in the Kerberos configuration file (krb5.conf).
Cannot find KDC for requested realm
No KDC was found in the requested realm.
Solution:Make sure that the Kerberos configuration file (krb5.conf) specifies a KDC in the realm section.
cannot initialize realm realm_name
The KDC might not have a stash file.
Solution:Make sure that the KDC has a stash file. If not, create a stash file by using the kdb5_util command, and try running the krb5kdccommand again. The easiest way to start krb5kdc is to run the /etc/init.d/kdc script.
Cannot resolve KDC for requested realm
Kerberos cannot determine any KDC for the realm.
Cannot reuse password
The password that you entered has been used before by this principal.
Solution:Choose a password that has not been chosen before, at least not within the number of passwords that are kept in the KDC database for each principal (this policy is enforced by the principal's policy).
Can't get forwarded credentials
Credential forwarding could not be established.
Solution:Make sure that the principal has forwardable credentials.
Can't open/find Kerberos configuration file
The Kerberos configuration file (krb5.conf) was unavailable.
Solution:Make sure that the krb5.conf file is available in the correct location and has the correct permissions. This file should be writable by root and readable by everyone else.
Client/server realm mismatch in initial ticket request
A realm mismatch between the client and server occurred in the initial ticket request.
Solution:Make sure that the server you are communicating with is in the same realm as the client, or that the realm configurations are correct.
Client or server has a null key
The principal has a null key.
Solution:Modify the principal to have a non-null key by using the cpw command of kadmin.
Communication failure with server while initializing kadmin interface
The host that was entered for the admin server, also called the master KDC, did not have the kadmind daemon running.
Solution:Make sure that you specified the correct host name for the master KDC. If you specified the correct host name, make sure that kadmind is running on the master KDC that you specified.
Credentials cache file permissions incorrect
You do not have the appropriate read or write permissions on the credentials cache (/tmp/krb5cc_uid).
Solution:Make sure that you have read and write permissions on the credentials cache.
Credentials cache I/O operation failed XXX
Kerberos had a problem writing to the system's credentials cache (/tmp/krb5cc_uid).
Solution:Make sure that the credentials cache has not been removed, and that there is space left on the device by using the df command.
Decrypt integrity check failed
You might have an invalid ticket.
Solution:Make sure that your credentials are valid. Destroy your tickets with kdestroy and create new tickets with kinit.
Make sure that the target host has a keytab file with the correct version of the service key. Use kadmin to view the key version number of the service principal (for example, host/FQDN_hostname) in the Kerberos database. Also, use klist -k on the target host to make sure that it has the same key version number.
df: cannot statvfs filesystem: Invalid argument
The df command cannot access the Kerberized NFS file system, which is currently mounted, to generate its report, because you no longer have the appropriate root credentials. Destroying your credentials for a mounted Kerberized file system does not automatically unmount the file system.
Solution:You must create new root credentials to access the Kerberized file system. If you no longer require access to the Kerberized file system, unmount the file system.
failed to obtain credentials cache
During kadmin initialization, a failure occurred when kadmin tried to obtain credentials for the admin principal.
Solution:Make sure that you used the correct principal and password when you executed kadmin.
Field is too long for this implementation
The message size that was being sent by a Kerberized application was too long. The maximum message size that can be handled by Kerberos is 65535 bytes. In addition, there are limits on individual fields within a protocol message that is sent by Kerberos.
Solution:Make sure that your Kerberized applications are sending valid message sizes.
GSS-API (or Kerberos) error
This message is a generic GSS-API or Kerberos error message and can be caused by several different problems.
Solution:Check the /etc/krb5/kdc.log file to find the more specific GSS-API error message that was logged when this error occurred.
Hostname cannot be canonicalized
Kerberos cannot make the host name fully qualified.
Solution:Make sure that the host name is defined in DNS and that the host-name-to-address and address-to-host-name mappings are consistent.
Illegal cross-realm ticket
The ticket sent did not have the correct cross-realms. The realms might not have the correct trust relationships set up.
Solution:Make sure that the realms you are using have the correct trust relationships.
Improper format of Kerberos configuration file
The Kerberos configuration file (krb5.conf) has invalid entries.
Solution:Make sure that all the relations in the krb5.conf file are followed by the "=" sign and a value. Also, verify that the brackets are present in pairs for each subsection.
Inappropriate type of checksum in message
The message contained an invalid checksum type.
Solution:Check which valid checksum types are specified in the krb5.conf and kdc.conf files.
Incorrect net address
There was a mismatch in the network address. The network address in the ticket that was being forwarded was different from the network address where the ticket was processed. This message might occur when tickets are being forwarded.
Solution:Make sure that the network addresses are correct. Destroy your tickets with kdestroy, and create new tickets with kinit.
Invalid flag for file lock mode
An internal Kerberos error occurred.
Solution:Please report a bug.
Invalid message type specified for encoding
Kerberos could not recognize the message type that was sent by the Kerberized application.
Solution:If you are using a Kerberized application that was developed by your site or a vendor, make sure that it is using Kerberos correctly.
Invalid number of character classes
The password that you entered for the principal does not contain enough password classes, as enforced by the principal's policy.
Solution:Make sure that you enter a password with the minimum number of password classes that the policy requires.
KADM err: Memory allocation failure
There is not enough memory to run kadmin.
Solution:Free up memory and try running kadmin again.
KDC can't fulfill requested option
The KDC did not allow the requested option. A possible problem might be that postdating or forwardable options were being requested, and the KDC did not allow it. Another problem might be that you requested the renewal of a TGT, but you didn't have a renewable TGT.
Solution:Determine if you are requesting an option that either the KDC does not allow or if you are requesting a type of ticket that is not available.
KDC policy rejects request
The KDC policy did not allow the request. For example, the request to the KDC did not have an IP address in its request, or forwarding was requested, but the KDC did not allow it.
Solution:Make sure that you are using kinit with the correct options. If necessary, modify the policy that is associated with the principal or change the principal's attributes to allow the request. You can modify the policy or principal by using kadmin.
KDC reply did not match expectations
The KDC reply did not contain the expected principal name, or other values in the response were incorrect.
Solution:Make sure that the KDC you are communicating with complies with RFC1510, or that the request you are sending is a Kerberos V5 request, or that the KDC is available.
Key table entry not found
There is no entry for the service principal in the network application server's keytab file.
Solution:Add the appropriate service principal to the server's keytab file so that it can provide the Kerberized service.
Key version number for principal in key table is incorrect
A principal's key version is different in the keytab file and in the Kerberos database. Either a service's key has been changed, or you might be using an old service ticket.
Solution:If a service's key has been changed (for example, by using kadmin), you need to extract the new key and store it in the host's keytab file where the service is running.
Alternately, you might be using an old service ticket that has an older key. You might want to run the kdestroy command and then the kinit command again.
login: load_modules: can not open module /usr/lib/security/pam_krb5.so.1
Either the Kerberos PAM module is missing or it is not a valid executable binary.
Solution:Make sure that the Kerberos PAM module is in the /usr/lib/security directory and that it is a valid executable binary. Also, make sure that the /etc/pam.conf file contains the correct path to pam_krb5.so.1.
Looping detected inside krb5_get_in_tkt
Kerberos made several attempts to get the initial tickets but failed.
Solution:Make sure that at least one KDC is responding to authentication requests.
Master key does not match database
The loaded database dump was not created from a database that contains the master key, which is located in /var/krb5/.k5.REALM.
Solution:Make sure that the master key in the loaded database dump matches the master key that is located in /var/krb5/.k5.REALM.
Matching credential not found
The matching credential for your request was not found. Your request requires credentials that are unavailable in the credentials cache.
Solution:Destroy your tickets with kdestroy and create new tickets with kinit.
Message out of order
Messages that were sent using sequential-order privacy arrived out of order. Some messages might have been lost in transit.
Solution:You should reinitialize the Kerberos session.
Message stream modified
There was a mismatch between the computed checksum and the message checksum. The message might have been modified while in transit, which can indicate a security leak.
Solution:Make sure that the messages are being sent across the network correctly. Since this message can also indicate the possible tampering of messages while they are being sent, destroy your tickets using kdestroy and reinitialize the Kerberos services that you are using.
