For mandatory locks, the file must be a regular file with the set-group-ID bit on and the group execute permission off. If either condition fails, all record locks are advisory.
Set a mandatory lock as follows.
#include <sys/types.h>
#include <sys/stat.h>
int mode;
struct stat buf;
if (stat(filename, &buf) < 0) {
perror("program");
exit (2);
/* get currently set mode */
mode = buf.st_mode;
/* remove group execute permission from mode */
mode &= ~(S_IEXEC>>3);
/* set 'set group id bit' in mode */
mode |= S_ISGID;
if (chmod(filename, mode) < 0) {
perror("program");
exit(2);
The operating system ignores record locks when the system is executing a file. Any files with record locks should not have execute permissions set.
The chmod(1) command can also be used to set a file to permit mandatory locking.
$ chmod +l file |
This command sets the O20n0 permission bit in the file mode, which indicates mandatory locking on the file. If n is even, the bit is interpreted as enabling mandatory locking. If n is odd, the bit is interpreted as “set group ID on execution.”
The ls(1) command shows this setting when you ask for the long listing format with the -l option:
$ ls -l file |
This command displays the following information:
-rw---l--- 1 user group size mod_time file |
The letter "l" in the permissions indicates that the set-group-ID bit is on. Since the set-group-ID bit is on, mandatory locking is enabled. Normal semantics of set group ID are also enabled.
